You can simplify the circuit by deleting the right side of the schematic ( Q2..)
Replace Q1 with Q2, swap the + and - input pins of the opamp, remove C1.
I am using a LM358 opamp, total fan current is 300 mA.
In order to get the circuit stable I used a 470 uF output capacitor, a 100 pF capacitor across the output of the opamp and the - input of the opamp, and a 22k resistor is series with the input control voltage.
