Author Topic: IAR view flash & ram size?  (Read 2313 times)
Offline Vindhyachal.taknikiTopic starter
« on: December 17, 2019, 06:26:34 am »
Which setting to enable in IAR to view how mch program and data memory is occupied? My code builds with zero error & zero warning. Earlier it used to Tools->Options->Messages->Enable All.
Now it dont show program/data size upon building.
Offline MosherIV
Re: IAR view flash & ram size?
« Reply #1 on: December 17, 2019, 01:41:44 pm »
Look in the linker output file. The linker should generate a link map and tell you how much ROM and Init vars in RAM uses.
Offline coppice
« Reply #2 on: December 17, 2019, 01:54:04 pm »
The linker file has the information you want. The annoying part is that, unless they've improved things recently,  its not in a nice tidy summary at the end, where it would be easy to locate and scan.
