Author Topic: UPS and ESD monitor puzzle  (Read 2312 times)
Offline openthomasTopic starter
« on: October 07, 2012, 12:00:15 pm »
So I have a 3m 724 esd workstation monitor. To monitor a antistatic mat the unit requires 2 grounds, one from the socket and another soft ground from say a radiator. You connect the soft ground to the mat, and from another connector on the mat back to the monitor.I connected the 724 monitor through my ups socket and the soft ground to a radiator, but the alarm shows that the mat is not grounded. However when I switch and connect it directly to the socket, the grounds appear equal and the alarm goes out. Why ? Why does the ups not pass ground ?
Re: UPS and ESD monitor puzzle
« Reply #1 on: October 07, 2012, 12:50:54 pm »
It should, but often this fault is not noticed, or the wire is left off to cut cost. You would have to open the UPS and check the wiring to be sure.
Offline amyk
« Reply #2 on: October 07, 2012, 12:56:36 pm »
A DMM also works for checking ground continuity...
« Reply #3 on: October 07, 2012, 03:17:20 pm »
I just run a continuity check from ground in the wall socket to ground on the UPS socket ? Safe ?
Online Monkeh
« Reply #4 on: October 07, 2012, 05:32:24 pm »
Why wouldn't it be?
