Author Topic: ic config  (Read 1186 times)
Offline Hornnumb2Topic starter
ic config
« on: January 19, 2019, 09:53:59 pm »
How do I know where pin one is on this, so I can replace. Thanks Michael
Re: ic config
« Reply #1 on: January 19, 2019, 10:18:01 pm »
Thanks I really could tell if that was a dot or not, yeah the chip I bought is already programmed. Michael
Offline james_s
Re: ic config
« Reply #2 on: January 19, 2019, 11:06:50 pm »
It's also marked on the PCB silkscreen, the notch indicates the end with pin 1. With the chip right side up, pin 1 is always the bottom-left corner, most of the time the text is printed right side up on the IC however I have seen pictures of a few examples where this wasn't the case. Never personally encountered one though.
