Author Topic: ic config  (Read 407 times)
Offline Hornnumb2
ic config
« on: January 19, 2019, 09:53:59 pm »
How do I know where pin one is on this, so I can replace. Thanks Michael
Offline blueskull
  • Country: cn
  • Power Electronics Guy
Re: ic config
« Reply #1 on: January 19, 2019, 10:00:20 pm »
The corner where there is a dot on the package is pin 1.
Top right corner.
BTW, it's a GigaDevice flash memory. You need to program the chip before soldering the replacement on
Offline Hornnumb2
Re: ic config
« Reply #2 on: January 19, 2019, 10:18:01 pm »
Thanks I really could tell if that was a dot or not, yeah the chip I bought is already programmed. Michael
Offline blueskull
  • Country: cn
Re: ic config
« Reply #3 on: January 19, 2019, 10:52:25 pm »
Top right corner. The dot is a small indent.
Offline james_s
Re: ic config
« Reply #4 on: January 19, 2019, 11:06:50 pm »
It's also marked on the PCB silkscreen, the notch indicates the end with pin 1. With the chip right side up, pin 1 is always the bottom-left corner, most of the time the text is printed right side up on the IC however I have seen pictures of a few examples where this wasn't the case. Never personally encountered one though.
