Hi guys
I have a newbie question on reading datasheets.
I'm planning to do some bread board tests with a T.I. SN74HC259N (8 bit addressable latch) and want to drive an LED on each of the Q0-7 outputs.
Checking the datasheet it seems to state the following:
(page 4) Continuous output current ... +/-20mA
(datasheet found on this page:
http://www.farnell.com/datasheets/1886232.pdf)
Does this refer to a 20mA
per pin current output maximum or is it for the entire outputs put together? I suspect the former, but would like to be sure (assuming that I'm looking at the right part of the data sheet!).
Many thanks for any advice given
