For me the LM35 is a PITA for digital electronics. It is analog so if you are using a DC-DC converter you should use some heavy filtering. Depending on the board layout, the DC-DC converter might introduce some heat to the system. I like the TO-220 version, it can be mounted on a big surface like a metal chassis. If you are using this with a digital circuit please do yourself a favor and get a humidity sensor IC with integrated temperatur sensor. Go for something that supports I2C, SPI or at least RS-232.
