Author Topic: Temperature indicator  (Read 1096 times)
Offline darinsquaredTopic starter
« on: December 12, 2016, 06:36:26 pm »
I want to build a circuit like this (from http://www.homemade-circuits.com/2015/01/4-led-temperature-indicator-circuit.html ) to measure temperature.  I will have three similar circuits (temp sensors) to measure temp at three different levels (TH1, TH2, and TH3).  I want to be able to compare each level to another sensor (THref).  Would I wire (THref ) in parallel to each sensor as a voltage divider?
 I calculated my thermistor R=12,000 Ohm at @ 20 Deg C.  How do you determine what the R1 value in each sensor?  As well, I want a 5-7.5 Deg C difference between each successive LED on each sensor.  How do I calculate R7, R8, R9, and R11 values to accomplish this?
Would I be better off using a microcontroller and Digital temp probes?
Offline kripton2035
Re: Temperature indicator
« Reply #1 on: December 12, 2016, 07:53:13 pm »
Well I don't know if it would be better, but it would take less space on the board.
« Reply #2 on: December 13, 2016, 03:08:44 pm »
Would this work?  Instead of using a voltage divider, apart from the initial one, I would use diodes (D) to do a 0.7V drop between each comparator lead.  I did not put in resistor values but I have them calculated.  Coming out of the comparator I go to a resistor and LED to ground.
