I have a circuit that involves a signal, resistors, optocoupler, decoupling caps, and 74hc4050 hex buffer.
I have 5 input signals. I'm using a Lite-on LTV-844s for 4 of the signals and an LTV814s for the 5th signal.
The only difference between the optocouplers is that one is a 4 channel, the other a single channel. All specs are the same otherwise.
I've attached a sketch of the schematic.
Like I said, the circuit is the same for all 5 channels. The only difference circuit-wise is that 4 channels are on one optocoupler and 1 channel is on the other smaller optocoupler.
If I connect my signal to channels 1-4, I get a nice signal from the output of the 74HC4050.
If I connect the exact same signal to channel 5, I get no output.
I've checked all of the physical connections. They are all good. I get all the values I expect between points.
If I change the resistor going to the input of the optocoupler on channel 5 from 4.7k to 2.2k, I then get output on Channel 5 through the 74hc4050.
I'm perplexed as to why, when all other things are equal, I need to drop from 4.7k to 2.2k on the input to get an output.
I have a theory. I'll link a picture of the board.
You can see, the physical layout on the board is different. There is ground plain on top and bottom of the board. Am I getting capacitance from how I laid the board out? Why would the lower value resistor overcome it?
I have so many questions about this. How should I test? I have a Rigol scope. Will putting a scope on there negate the built up capacitance at all if it's small? Did I violate a basic board design rule with having a ground plane on top and on bottom? Did I violate a rule by having that long trace running in parallel to the top ground plane? Am I being dumb thinking that the LTV844 is the same as the LTV814 except for channel count? Am I being dumb thinking that the capacitance would amount to anything that would have an affect on the circuit?
Thanks for any input.
Mike
