Author Topic: MC34063 issues  (Read 3849 times)
Offline MedoTopic starter
MC34063 issues
« on: August 26, 2011, 04:41:54 pm »
I tried to design 24V to 5V converter around MC34063 but I have stumbled upon some problems.
By all calculations I should get easy 5V but I measure over 8...
Could it be problem that I am using only few mA usually?
Board should work from cca 1-250 mA...
I dare not put PIC on this board before I am sure that it will not go out...
Do you have some generic component values for 24->5 conversion that would work with L=150uH?
Data I calculated is:
    R1=1.2K
    R2=3.6K
    Ct=1500pF
    Rsc=0.68
    L=150uH
    Co=470uF
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: MC34063 issues
« Reply #1 on: August 27, 2011, 12:01:05 pm »
what is the frequency ?
I put your data into http://dics.voicecontrol.ro/tutorials/mc34063/calculate.php assuming 100KHz and got some very different values, you may want to recheck your calculations
Re: MC34063 issues
« Reply #2 on: August 27, 2011, 11:46:33 pm »
70 kHz
Re: MC34063 issues
« Reply #3 on: August 28, 2011, 06:25:13 pm »
Yep, I made "factor of ten" error in my spreadsheet...
Thanks!
