I tried to design 24V to 5V converter around MC34063 but I have stumbled upon some problems.
By all calculations I should get easy 5V but I measure over 8...
Could it be problem that I am using only few mA usually?
Board should work from cca 1-250 mA...
I dare not put PIC on this board before I am sure that it will not go out...
Do you have some generic component values for 24->5 conversion that would work with L=150uH?
Data I calculated is:
R1=1.2K
R2=3.6K
Ct=1500pF
Rsc=0.68
L=150uH
Co=470uF
