Hey Guys new to EEVBlog forum. But i have a ifi hip dac, a battery powered amplifier. I was charging it the other day, but i plugged it into my overseas mobile charger. And the AU adapter if moved via the cable can spark ( need a better adapter ). But i was hesitant and plugged it into the portable AMP. I may have plugged the USB-C laptop power but more likely the overseas mobile charger. Either way i left it. And when i came back. The Amp would not turn on nothing- zip.
So i took out the four screws and using macro mode, i found out a SMD component blew. As can be seen by the pictures. The SMD components around it that look similar no markings. Apart from the one that blew. So even if it didn't blow, or wasnt as bad. I doubt i would of been able to find out what the spec was aside it saying R200. I am a new Nub to the electronic world so not sure what the r200 represents...
Any and all help appreciated. Have more pics if need it. If want to know more don't hesitate to ask.
I want to know what the electronic SMD part was that blew?
As not other sign on amp has anything blown or burnt, aside that one SMD, with some scorching on the SMD Capacitor near it
