Perhaps I am crazy here, but if it is a diode and it reads 0.46V one way and open the other, then it would seem to be functioning properly. This suggests that it is not your problem. Move on.
On the other hand, if it is a zener, and you want to check it's zener Voltage, then take readings with the circuit powered up.
