Is it worth it?
I have only had one bad experience with a China manufacturer and recently they said they can't do my boards in black silk screen but they can do them in green.
Apparently their black silk screen cant go between pads <0.35mm
I haven't had one "really" bad experience with the chinese PCB manufacturers, only minor inconveniences like silkscreen too flimsy (because i misinterpreted the specs) or those damn batch numbers they tend to print somewhere on your PCB without asking.
This is what I prefer to do:
IF i need something ASAP, I order directly from one of the PCB houses in Germany I have used previously and know they are good - namely Würth and IBR Ringler.
I also order from those two if I absolutely need the best quality I can get and/or need something special, like a certain material the chinese don't cover with their standard offers.
On most other cases I go to china, especially for high volume small size stuff, the local manufacturers just can't beat the price.
Attached is a sample from my last order... 1000 of them did cost me twice the postage... Can't beat that.
