Author Topic: Identifying capacitors - looking for help  (Read 841 times)
Offline Strand17Topic starter
« on: September 11, 2017, 09:20:56 pm »
Hello,
I need help in identifying the type and if possible also the manufacturer of some capacitors.
The capacitors are rectangular, 7.5x5.5x2.8 mm and are used for both decoupling and filtering in a small low noise amplifier which is 10-15 years old. Two markings are used, "156" (15uF?) and "686" (68uF?).
Any suggestions would be very welcome!
Jonas
Offline David Hess
  • DavidH
Re: Identifying capacitors - looking for help
« Reply #1 on: September 11, 2017, 09:53:25 pm »
I think you got the values right at 15uF and 68uF.  Given the case size and the polarity marking, I think that makes them solid tantalum capacitors.
« Reply #2 on: September 13, 2017, 07:42:44 pm »
Thanks a lot!
Jonas
