Hello, i just repaired a thermostat (i replaced an electrolytic capacitor which was out of spec) and now i try to analyze how the rest of the board works, and i'mm halfway through making a schematic.
There are a few items i cannot understand, for which i kindly request your help :
1) R18 = The 5 pin yellow resistor network : 5X-6-182LFthis is a resistor network component, based on 1.8k resistors
but i spent 2 hours trying to find a datasheet or explanation about it
it is NOT a simple resistor network (not single type, not bus type)
as far as i have checked (there is nothing in parallel on the schematic) :
- from pin 1 to pin 2: 1.8k
- from pin 1 to pin 3: 3.6k
- from pin 1 to pin 4: 5.4k
- from pin 1 to pin 5: 7.2k
So the resistors are in series between each pin !
I cannot find the datasheet for any such resistor network, can you help me ?
I find a lot of components with 1 or 2 in the second part of the label, but never with a 6 in it !
PS: Actually that's quite great, because the commutator/slider above maps each commutator position to a different (cumulated) resistor value, which is output to the same pin on the microchip.
You can see a photo bellow (yellowish 5 pin component)
2) The microchip "60-MECO" or "60-MEC0"It is an 18 pin DIP package. I guess this is a custom made chipset, second identification label : 12426MU (first heater) 1225P8H (second heater)
Can anyone help me find some documentation ?
You can see it in the second photo :
3) The ceramic oscillator "400(Cm)131"My guess is that it is a ceramic oscillator (it took me 2 hours to discover that such components existed !)
As far as i can tell from what i have read, it should oscillate at around 4Mhz (i do not have a scope to verify it)
Am i right ? and how can i be sure ?
You can see it in the photo above
4) the 4 resistors with a red bodyBut there are a few other resistors with red bodies. These are on the part of the board which is hotter (discoloration), but are in series and simply dropping 80V and dissipate about 1/3W each to allow a led to be on when AC power is on.
For these 4, i wonder what the body color means (power dissipation capacity ? heat resistance capacity ?) please enligthen me... if it is heat, i don't know why R20 is red too, and not it's neighbours
You can see them (R20/R21/R22 and RP1) in the photo bellow :
5) There is a BIG BIG resistor (RP1) which is obviously some power capable resistorI don't know (yet) what the big resistor is doing, not what its power requirement should be
Simple question, how do you usually find out the resistor spec (wattage) when analyzing a circuit ?
Same here, you can see it in the above photo
Thanks in advance for your help, i'm kind of new, but i'm having fun learning.Regards,
nipil
PS: i cannot get attachement inserts to work, i'll edit the post later, sorry
