I have a 18V/30A switching power supply that is acting strange ("standard" chinese SMPS). It can be adjusted from 11.5V to 20.5V, and I'm using it to power an induction heating circuit. I usually start at minimum voltage and crank it up.
I have made a new induction circuit which is power powerful, with larger coil and crucible. It starts as 11.5V/16A under load. I noticed that when I reached ~15V the voltmeter module connected to the supply showed decreasing voltage... I didn't pay much attention and thought it might be the voltemeter's wiring that has some issues, and as the cooling fan of the induction circuit kept having higher pitch. I ran like that for a while, wihtout any problem (ammeter reading 23-24A), melted some aluminium, no apparent problem.
Today I took a closer look at highest setting (20.5V)... verified the voltmeter... same problem, I connected my multimeter to the supply, above 15V it started to have crazy readings... I switched to AC and it read a good stable 3V, brought the oscilloscope... see the picture attached... huge 3Vpp ripples at 100Hz (nothing visible < 15V/20A appears after that)
I naturally suspect the power supply (100Hz is the frequency of rectified AC mains), and some kind of protection circuit kicking in and out.
I tried connecting 2 10000µF caps to the supply output... voltmeter then had a nice clean 15V reading and ammeter didn't go higher than 20A, also the cooling fan didn't seem to run faster as I tried to go above 15V.
Any idea what to look for, is this fixable? Supply is supposed to be 540W not 300
David.
