Author Topic: Through Hole to SMD components  (Read 1198 times)
Offline anishkgtTopic starter
  • Country: qa
    • George Hobby
« on: August 04, 2017, 07:51:03 pm »
Hi All,
i am searching for a few SMD components and cannot seem to find the 0.1uf 400v (https://www.digikey.com/product-detail/en/nichicon/QXK2G104KTPTZH/493-3574-ND/2118520) in an SMD form. Are these in through hole size only ?
Online Zero999
  • 0999
Re: Through Hole to SMD components
« Reply #1 on: August 04, 2017, 09:02:15 pm »
Hi All,
Through hole is more common for higher voltage components because the creapage distances are normally greater.
Here's an alternative in SMT format, but the AC voltage rating is only 160V, even though the DC rating is the same at 400V.
https://www.digikey.com/products/en?keywords=LDEME3100KA5N00
Here's one rated to 200VAC but RS don't have any in stock and Digikey don't stock them at all.
http://uk.rs-online.com/web/p/pen-film-capacitors/8752399/
  • Country: qa
    • George Hobby
« Reply #2 on: August 04, 2017, 09:15:45 pm »
Thanks i will just stick to the through hole for this component.
