Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Impedance calculation double sided board
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Impedance calculation double sided board (Read 579 times)
FriedMule
Frequent Contributor
Country:
Can make even the simplest task look imposible.
on:
August 15, 2019, 12:36:05 am »
Hi I have tried to calculate track impedance, using a online calculator but I do not know how to calculate my board.
It has a track on one side and a fill layer on the other side, both connected by vias.
How do I calculate the total impedance?
Logged
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
Illusionist
Regular Contributor
Country:
Why is the rum gone?
Re: Impedance calculation double sided board
Reply #1 on:
August 15, 2019, 10:16:21 pm »
There's a really useful, free tool you can download here:
http://www.saturnpcb.com/pcb_toolkit/
The impedance is calculated on: PCB (dielectric) material, thickness, copper thickness and track width. Note that board thicknesses are often given as copper+dielectric thickness, so if it's double sided 1.6mm, the dielectric is 1.6mm minus 2* the copper thickness.
The tool above is really handy because it does some of the conversions for you (for instance converts oz of copper layer to mm/mils etc). It can do a lot - have a play and get used to it.
Logged
Agilent 34410A, GW Instek 8251A, Thurlby 1905A, Siglent DS1104X-E(unlocked), SDG1032X(unlocked), Micsig DP10013 MX, LeCroy PP008 500MHz Probes, Fluke 179
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Reply #2 on:
August 15, 2019, 10:24:17 pm »
So the track is connected to the fill with a via? And you need to know the impedance of this effective transmission line stub..?
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
