Author Topic: Faulthy PSU?  (Read 2045 times)
Offline anfangTopic starter
Faulthy PSU?
« on: January 02, 2017, 02:27:10 pm »
I have purchased a brand new power-supply from a reputable seller here in the country. However, without load it produces an extremely annoying buzz when I select a specific voltage:
https://sendvid.com/8g69q1v4
Should I return this as faulty, or can it still be used ?
Offline Zero999
  • 0999
Re: Faulthy PSU?
« Reply #1 on: January 02, 2017, 02:41:32 pm »
That sort of thing is common.
How much did you pay for it?
Have you looked at the output on an oscilloscope? Does it meet its ripple specification?
Offline Kleinstein
Re: Faulthy PSU?
« Reply #2 on: January 02, 2017, 02:45:31 pm »
The sounds very much like a relay switching very fast. If this is done with a considerable load to the supply, it will relatively fast damage the relay contacts and maybe other parts. So this unit is broken and should be returned.
Typically such supplies have a relays or two to switch between transformer taps, depending on the output voltage. Normally there is quite some hysteresis to prevent to fast switching. Here the hysteresis is missing or way to small - likely something like a missing resistor or solder joint / broken line.
The following users thanked this post: MK14
Re: Faulthy PSU?
« Reply #3 on: January 02, 2017, 02:46:12 pm »
edit:  now confused as someone says its broken and other one perfectly fine.. hmm
It's this one for your info:
http://www.velleman.eu/products/view/?country=be&lang=de&id=348800
https://www.amazon.com/Velleman-PS1503SBU-Digital-Display-Backlight/dp/B000I3X7Z4
I actually paid only $70 for it (66 euro's). Unfortunately I don't have an oscilloscope (yet), and not even the wires, so cannot test it under load.
« Last Edit: January 02, 2017, 02:48:53 pm by anfang »
Offline Richard Head
Re: Faulthy PSU?
« Reply #4 on: January 02, 2017, 02:51:10 pm »
You would think that an extra 60 seconds spent on actually testing the unit after manufacture would be worthwhile for them. Apparently not.
Offline Zero999
  • 0999
Re: Faulthy PSU?
« Reply #5 on: January 02, 2017, 02:53:46 pm »
Because, in the absence of all the information, people make assumptions?
I assumed it was a switched mode power supply, which often make noises when lightly loaded.
Going by that, it seems like it's a linear power supply, in which case it's quite likely Kleinstein is right: a relay is buzzing.
The following users thanked this post: anfang
Offline MK14
Re: Faulthy PSU?
« Reply #6 on: January 02, 2017, 03:26:44 pm »
Yes, return it as faulty.
I've seen the video, and definitely think it is faulty.
If it is NOT faulty, then it is a VERY bad design, which does not have suitable hysteresis on the (presumably) relay switching voltages.
« Last Edit: January 02, 2017, 03:28:39 pm by MK14 »
Re: Faulthy PSU?
« Reply #7 on: January 02, 2017, 03:48:37 pm »
hi, I didn't mean any offense. due to lack of emotional communication through chat I might have stated my state of confusion in less than ideal way. Apologies if this was taken as offense :P.
Thanks all! I'll return this supply.
Offline Zero999
  • 0999
Re: Faulthy PSU?
« Reply #8 on: January 03, 2017, 11:39:58 am »
No offence taken. I was just pointing out the fact that you'll often find people on online forums give differing responses. Sometimes it's because one person has overlooked something or has less experience than the others but it could also be that both answers are right.
