Author Topic: Morning clampers!  (Read 668 times)
Offline PerranOakTopic starter
Morning clampers!
« on: December 03, 2020, 01:47:40 pm »
I was intrigued to learn of the "clamper circuit" - see attached.
I fiddled about in LTSpice but could only get the lowest peak to -164mV; so it's still a bit negative. The Schottky gives the best (i.e. closest to zero or +ve) even though its forward voltage is supposed to be 450mV.
I saw another circuit that uses a voltage source (say, a battery) "under" the diode to boost the level but this seems like cheating(!)
My questions are:
Is a Schottky the best diode choice?
Why is the lowest point 164mV and not 450mV?
Is there a way to stop it going negative without a battery?
Cheers.
You can release yourself but the only way to go is down!
RJD
Online Berni
  • Country: si
Re: Morning clampers!
« Reply #1 on: December 03, 2020, 02:04:46 pm »
Yep schotkey is the best you can do with this setup.
The way to prevent it from going negative is to use 4 diodes in a specific forward biased configuration like it is used here:
https://www.maximintegrated.com/en/products/analog/analog-switches-multiplexers/MAX4936.html
Its a bit of an unusual circuit that can handle very large voltages, while instead having the limitation of the signal it is passing getting clamped before it even gets to 0 so it instead needs a negative supply if you want your output signal to actually reach 0 at all. A very popular use of this circuit is medical ultrasound machines to protect the milivolt RX amplifiers from the >100V TX pulses.
The following users thanked this post: PerranOak
Offline TimFox
« Reply #2 on: December 03, 2020, 02:46:45 pm »
Another name for this circuit, especially in analog video circuits, is "DC Restorer", which is a misnomer.  It is used in AC-coupled signal chains to get the "black" level in a waveform that is known to be unipolar (i.e., positive or negative-definite).  A better method for video purposes is to use a FET switch ("keyed clamp") that is turned on at a specific interval ("back porch") of the waveform, instead of the diode.
