Author Topic: Transformer identification..  (Read 1103 times)
Offline KBJ62Topic starter
  • Country: in
« on: March 20, 2021, 06:11:07 am »
Hey,
        Trying to figure out what sort of transformer this is..
Online drvtech
Re: Transformer identification..
« Reply #1 on: March 20, 2021, 10:21:46 am »
It's a Coilcraft part. Looks like one of their coupled inductors/transformers but I can't see one on their website with that number on it. Have a trawl at coilcraft.com
Online drvtech
« Reply #3 on: March 21, 2021, 09:54:05 am »
Can't be that one - it only has two windings.  The one in the pic has six pads so must have three windings.
Offline drussell
  • Hardcore Geek
« Reply #4 on: March 21, 2021, 11:17:46 am »
Why not?  Things like the LPH8045 series are 1:1:1...
You can use them as three separate windings or wire them up to make them into 2:1 or whatever, depending on what you're trying to accomplish.
Online Zero999
  • 0999
« Reply #5 on: March 21, 2021, 01:19:20 pm »
Have you checked that all six pads are connected to the windings? Quite often not all of the pins are connected and are just for mechanical support.
  • Country: in
« Reply #6 on: March 22, 2021, 05:22:50 am »
Wow thanks for the help. The device is used in LVDC generation ( 100V - 400V). It is used for voltage setup but I had a problem identifying this exact part. It could be their LPR series (low profile 1:N trnsformer).
Offline drussell
  • Hardcore Geek
« Reply #7 on: March 22, 2021, 08:05:33 am »
Yeah, I figured that is what they were used for but I couldn't find an actual datasheet for that HV53001 driver "with boost" or the HV53011 there to try to guess the circuit values or see if there was a recommended inductor formula or suggested part in an example or something.
I didn't see one that matched in my quick look through a couple different series, and various searches for anything likely with a -352 suffix only yielded a regular ferrite rod through-hole inductor, so you'll have to do a bit more digging.
Remember, it is also possible it is some sort of custom part, it may not be in a standard series datasheet.
Offline crossroad
  • Avian World Theory
« Reply #8 on: March 22, 2021, 08:19:22 am »
My 2 cents from brief observation: looks like there's tracks going to three pads, one pad is to a power pour, and one is to ground, with one more to some sort of via stitching. I'd imagine that they're for more than just mechanical support in this instance
