Author Topic: Improving on cheap solderless breadboards.  (Read 529 times)
Offline buzzawak
  • It's all about the data.
« on: October 19, 2019, 03:06:00 am »
I have decided to have a go at building an 8bit breadboard computer.
I have scrounged up all the components needed and looking at the cheap solderless breadboards.
I need about 12 x 830 pin breadboards and can't justify the cost of the top quality units.
The cheap $3-5 units all seem to have a bow in them, I guess due to the moulding process.
Has anyone had a go at correcting the fault in these and to what level of success?
« Last Edit: October 19, 2019, 03:10:32 am by buzzawak »
Online Whales
    • Halestrom
Re: Improving on cheap solderless breadboards.
« Reply #1 on: October 19, 2019, 03:37:17 am »
Bow?  How big?  My 830pt boards all lie flat, I have not noticed this problem.
(N.B. they're crazily cheap from LCSC, so I tend to order them in batches of 5-10)
The following users thanked this post: Brutte, rstofer
Offline buzzawak
« Reply #2 on: October 19, 2019, 05:07:47 am »
I started with one from Jaycar Electronics that you could actually rock, which I returned.
Since then I have bought two off Aliexpress (different brands) both have a slight bow.
The bow is stopping the board from sitting flat on the table. I guess If I used the backing tape It would not be so noticeable.
The boards also have two mounting holes on the underneath (under the backing tape) on the power rails, I could use those to force the board into shape.
Offline buzzawak
« Reply #3 on: October 19, 2019, 05:23:46 am »
That is a bloody cheap price.
@Whales, you consider them value at that price?
Online Whales
    • Halestrom
« Reply #4 on: October 19, 2019, 06:27:56 am »
I've just stripped the foam off the back of a new one, it sits flat on my desk fine and I can't make rocking noises with it or feel it rocking.
I suspect these boards will be made of polystyrene.  Do you store them anywhere that gets above ambient temperature?  Is your mailbox a dutch oven?
Given that you are using them without foam on the bottom: the metal clips could be sticking out underneath unevenly.  Every time you push a wire in you may push these out slightly, they're removable.
Otherwise: curved desk? :D
What do you mean by 'value'?  They're the same boards, AFAICT, as all of the other cheap 830pt boards.  Opinions will vary greatly, from my experience these do have a life limit before connections into them get very unreliable.
« Last Edit: October 19, 2019, 06:29:30 am by Whales »
The following users thanked this post: buzzawak
Offline buzzawak
« Reply #5 on: October 19, 2019, 06:55:26 am »
I leave the foam backing on, I just don't peel off the cover and stick it down. I was thinking that sticking them down may help.
They arrived with the bow in them on a day that was moderate weather-wise.
I guess by "value" I mean are you happy with them considering the price.
« Last Edit: October 19, 2019, 07:00:53 am by buzzawak »
Offline Peabody
« Reply #6 on: October 19, 2019, 02:06:04 pm »
Julian Ilett built a breadboard computer, and went deep into the breadboard problem.  Apparently he found some he liked:
The link in that video no longer works, but that seller has these:
https://www.ebay.com/itm/5PCS-Solderless-MB-102-MB102-Breadboard-830-Tie-Point-PCB-BreadBoard-Arduino/253358454189
But I'm not sure they are the same thing as Julian got.  If interested, you might message the seller and ask.  It looks like Julian's were branded "Stellarsource".
« Last Edit: October 19, 2019, 02:13:02 pm by Peabody »
The following users thanked this post: Whales, Teti, buzzawak
Offline buzzawak
« Reply #7 on: October 19, 2019, 10:33:52 pm »
Thanks @Peabody for the information.
Offline Teti
« Reply #8 on: October 22, 2019, 10:21:15 pm »
I've bought about half dozen of MB-102 breadboards (the same as Julian) and they are decent quality. I would recommend them.
The following users thanked this post: I wanted a rude username, buzzawak
