I've just stripped the foam off the back of a new one, it sits flat on my desk fine and I can't make rocking noises with it or feel it rocking.
I suspect these boards will be made of polystyrene. Do you store them anywhere that gets above ambient temperature? Is your mailbox a dutch oven?
Given that you are using them without foam on the bottom: the metal clips could be sticking out underneath unevenly. Every time you push a wire in you may push these out slightly, they're removable.
Otherwise: curved desk?
@Whales, you consider them value at that price?
What do you mean by 'value'? They're the same boards, AFAICT, as all of the other cheap 830pt boards. Opinions will vary greatly, from my experience these do have a life limit before connections into them get very unreliable.
