Hello
I wanted to use an LSM9DS1 on my PCB but there is no PCB design recommendation in the datasheet.
To make the magnetometer work in a reliable way, should I remove the ground plane, on all layers of the PCB, under and surrounding the chip or is it not necessary???
Thank you
