Author Topic: Getting half value in the output of charge pump  (Read 511 times)
Offline rajbuddyTopic starter
« on: October 28, 2022, 12:35:45 pm »
Hello guys,
I have made a charge pump circuit to the microcontroller where I am giving 3.3V to charge pump but I am getting 1.6V at the output which is insufficient to start the uC. Where am I getting wrong? Kindly check.
Br,
Raj
Offline MathWizard
Re: Getting half value in the output of charge pump
« Reply #1 on: October 29, 2022, 02:03:40 am »
https://www.analog.com/media/en/technical-documentation/data-sheets/3240fb.pdf
What voltage do u need ? It says
With input voltages greater than the regulated output voltage the LTC3240 operates as a low dropout regulator. Once the input voltage drops within 100mV of the regulated output voltage the part automatically switches to step-up mode. In step-up mode the LTC3240 operates as a constant frequency (1.2MHz) doubling charge pump.
I never tried any charge pump circuits. How noisy are they compared to using inductor based switching sources ?
« Reply #2 on: November 02, 2022, 08:23:10 am »
i need 3.3V to be exact to start my microcontroller but it is giving half like 1.6 somewhere
