Author Topic: In an LC tank, what limits (or defines) the voltage?  (Read 3080 times)
Offline joeyjoejoeTopic starter
« on: September 17, 2018, 12:51:04 am »
As the subject reads... what limits the voltage in an LC tank? Is it the saturation level of the inducctor that defines the maximum energy stored in the system?
Further, what sort of formulas are used to figure out these theoretical maximums?
Offline drussell
  • Hardcore Geek
Re: In an LC tank, what limits (or defines) the voltage?
« Reply #1 on: September 17, 2018, 01:43:27 am »
According to the 1963 edition of the ARRL handbook that just happened to be in front of me:
Voltage Rise at Resonance
When a voltage of the resonant frequency is inserted in series in a resonant circuit, the voltage that appears across either the inductor or capacitor is considerably higher than the applied voltage.  The current in the circuit is limited only by the resistance and may have a relatively high value; however, the same current flows through the high reactances of the inductor and capacitor and causes large voltage drops.  the ratio of the reactive voltage to the applied voltage is equal to the ratio of the reactance to resistance.  This ratio is also the Q of the circuit.  Therefore, the voltage across either the inductor or capacitor is equal to QE, where E is the voltage inserted in series with the circuit.
Example:  The inductive reactance of a circuit is 200 ohms, the capacitive reactance is 200 ohms, the resistance is 5 ohms, and the applied voltage is 50.  The two reactances cancel and there will be but 5 ohms of pure resistance to limit the current flow.  Thus the current will be 50 / 5 or 10 amperes.  The voltage developed across either the inductor or the capacitor will be equal to its reactance times the current, or 200 X 10 = 2000 volts.  An alternate method: The Q of the circuit is X / R = 200 / 5 = 40.  The reactive voltage is equal to Q times the applied voltage, or 40 X 50 = 2000 volts.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: September 17, 2018, 06:43:26 am »
An LC tank cannot exist alone, something is coupling energy to it.
The impedance of that source/load, and the impedance of the tank, is what defines it.
For a series RLC network, for example, the resonant impedance is Zo = sqrt(L/C), and the higher this is compared to the ESR, the higher the multiplication ratio, also known as the quality factor, Q = Zo / R.
If you assume a perfectly lossless inductor and capacitor, and a constant voltage source (no resistance), you will get nonsense results, because no such circuit can exist. :)  For there to be power transfer, there must be resistance in the circuit!  And therefore, there will be some finite nonzero Q, and everything else follows. ;)
Seven Transistor Labs, LLC
« Reply #3 on: September 17, 2018, 09:52:54 pm »
Dang, that's some complicated stuff. I feel like I could take a university course on this and still not know it :) Any recommended resources to get started on these topics? Ie. moving out of digital world... :)
Offline T3sl4co1l
« Reply #4 on: September 18, 2018, 03:14:01 am »
Well, if it makes you feel any better, it's (usually?) a first year uni class (right after DC steady state -- circuits, resistors, voltages and currents).
Although, even after four years and a steep dropout rate, I suspect few graduates actually remember how to do it.
Well, maybe that doesn't help much. :P
Are you familiar with DSP systems?  Suppose you're doing that, but instead of integers* in a register, you have continuous values, with units attached (voltage/current), and the coefficients are the impedance ratios in the circuit.  That might help?
*Or floats, but they're still some number of bits, not an actual real number.
The final step of course is not just removing quantization (replacing it with Johnson noise, or other noise sources as needed for the model), but going from difference equations (fixed timestep) to differential equations (continuous time).  For well-behaved systems, this is surprisingly straightforward; not that differential equations are ever terribly easy to solve, but for LTI** systems, it leads into pole-zero analysis, and hence you have engineers talking about poles and zeroes in a system's frequency response.
**Linear time-invariant.  Basically, the equation doesn't depend on any other variable in the system: it can be written as a polynomial in differentials (i.e., derivatives of the state variable, multiplied by constant coefficients).  There aren't any coefficients depending on time, or on the state variable.  (Except for a "source" function, which is separable from the rest of the equation.)
This won't mean anything if you don't have a calculus background, so don't mind that in that case -- suffice it to say, it's the simplest, easiest case, one that is actually tractable by hand (once you do have a calculus and diff eq background).
If you do know DC analysis, then AC is the same, but on the domain of complex numbers (i.e., pairs of real numbers -- one associated with the "imaginary" constant j, such that j*j = -1, and you just write everything out that way and see what follows), and with impedance functions rather than constant resistances.  So, everywhere you would write R, you write R for a resistor, jωL for an inductor, or 1 / (jωC) for a capacitor.  Analysis works exactly the same, so that, say, the resistance divider equation Vo/Vi = R2 / (R1 + R2), becomes the impedance divider Vo/Vi = Z2 / (Z1 + Z2), where Z1 and Z2 are whatever their component impedances happen to be.
You can figure out some basic things, like the voltage or current gain of a series or parallel resonant network, with respect to frequency, and where resonance is.  The algebra is somewhat nontrivial, so do take it easy, don't get overwhelmed. :)
Proving it in general -- for an LC or RLC filter, say -- is much more difficult, but there are proofs for that, and frameworks to use. :)
