Author Topic: In Over My Head... Is this going to explode?  (Read 1037 times)
Offline RocketCat20Topic starter
« on: March 21, 2019, 01:04:38 am »
I have the circuit described in the images attached. Please ask any questions you have. I just want to know if this circuit looks problematic to anyone. The LED includes a resistor and can handle the 24V. Thanks!
Offline coppercone2
Re: In Over My Head... Is this going to explode?
« Reply #1 on: March 21, 2019, 01:13:05 am »
put a fuse
« Reply #2 on: March 21, 2019, 01:15:20 am »
Offline RobertHolcombe
« Reply #3 on: March 21, 2019, 03:32:46 am »
Fuse the wire connected to the positive battery terminal, as close as possible to the battery terminal. This is purely to protect the wiring from a possible short circuit.
Fuse rating is based on the ampacity of the wire used, if not sure look up AWG ampacity table for reference. You don't have to fuse to the maximum ampacity of your wiring, eg; your wiring can supply 30A, but your circuit will never draw more than 5 amps during normal use - I would use a 7.5 or 10 amp fuse.
Offline coppercone2
« Reply #4 on: March 21, 2019, 04:20:20 am »
read the littlefuse documentation to get a more clear idea of how fuses work. it can get rather complicated to specify them optimally. the jist of it depends on inrush current, peak current/sustained current and life time of the fuse (you can theoretically specify a fuse to only work for 100 power up cycles for instance, but the tollerances of a fuse are probobly pretty large compared to numbers you normally associate with electronics). The more you overrate (assuming its not a specialty fuse like slow, medium, time delay, etc) the more cycles you can get from it, but the less optimal the protection it offers will be.
« Last Edit: March 21, 2019, 04:22:25 am by coppercone2 »
Offline mikerj
« Reply #5 on: March 21, 2019, 08:43:49 am »
You have your 5v Arduino supply connected directly across an ammeter, so smoke and flames are a definite possibility.
