Thanks, Ed!
I've simply measured freq. to channel 1, with internal timebase.
Should I connect ref out of the counter to ch1, and the GPSDO to ch2, and measure time interval 1 to t.i. 2, gated to 1 sec?
It seems more like what you've described as resolution, below are the plots.
The output of the GPSDO is square, it has differential buffer, connected to one transformer like these, used in cheap routers WAN inputs.
Actually, the GPSDO is with it's default settings.
Before i posted my firs measurements, I've tried and have set it to auto elevation mask - it calculates between 15 and 25 degrees, depending on what antenna I connect to it.
I have left it to def., haven't toched the antenna, and measured again to havethe plots below, in order to compare similar environments.
I will try and set it to auto again later, since the antenna is on the roof of my garage, about 3 meters above the ground, and there are
two houses near it - one on SE, and one on NW position, as per LH screen.
I see something strange in this plot - the Sun, and all sattelites are hopping several degrees, maybe these positions are wronglly calculated by the reciever from reflected signals I let sneak in, because of the low elevation mask?
BR
Ivo
