Author Topic: B3603 alternative for +-12V  (Read 1711 times)
Offline charonmeTopic starter
  • Country: sk
« on: April 24, 2018, 12:08:38 pm »
could you please recommend an alternative for the B3603 which could I use to generate +12V, GND, -12V and have current limiters and ampmeters on both rails? (<300mA is sufficient, noise doesn't matter much)
I tried connecting two B3603s to a mean well +-15V PSU but they apparently can't work like that
Offline madires
  • A qualified hobbyist ;)
Re: B3603 alternative for +-12V
« Reply #1 on: April 24, 2018, 12:47:06 pm »
How did you wire the PSU and the two B3603s? A diagram could be helpful.
  • Country: sk
« Reply #2 on: April 24, 2018, 01:16:46 pm »
There is 2.8v potential between the first out- and the second out+.
When I connected them, I measured <1mA through the connection, but the second B3603 outputted 14.8V regardless of what voltage I set the B3603 to output.
The same happened when I tried connecting out+ to the mean well com
Offline madires
« Reply #3 on: April 24, 2018, 02:05:23 pm »
I've found a circuit diagram for the B3603 on https://github.com/baruch/b3603. If you have a look at the voltage & current controls you'll see what causes the issue (feedback tied with local Vcc). I don't know any similar modules, but I'd recommend to check their circuit before buying. Otherwise you might run into the same problem again. Or you could go for a classic lab PSU design with opamps and pass transistors.
  • Country: sk
« Reply #4 on: April 25, 2018, 06:39:20 am »
that's why I'm looking for a similar module that would give me +12v, gnd and -12v (the voltage doesn't even have to be adjustable)
  • Country: sk
« Reply #5 on: April 25, 2018, 12:57:41 pm »
I just realized I could try this
« Last Edit: April 25, 2018, 12:59:59 pm by charonme »
  • Country: sk
« Reply #6 on: April 26, 2018, 04:22:26 pm »
nah, didn't work :(
I'll probably have to look for a cheap benchtop psu with +,- and gnd outputs
Offline madires
« Reply #7 on: April 26, 2018, 05:36:58 pm »
Do you need the PSU to power a specific project or for typical lab use?
  • Country: sk
« Reply #8 on: April 27, 2018, 08:32:44 am »
specifically for testing equipment (based mostly on opamps) that is powered by +12V and -12V power
« Last Edit: April 27, 2018, 09:05:20 am by charonme »
Offline madires
« Reply #9 on: April 27, 2018, 09:30:35 am »
In this case I'd recommend a small linear regulated lab PSU. Cheap lab SMPSUs are quite noisy.
Offline nanofrog
« Reply #10 on: April 27, 2018, 01:20:38 pm »
Seconded.  :-+
Check the used market, as you'll do a lot better there IME. Dual, triple, and quad channel supplies offer a better value than a bunch of individual ones.
Do get one that has both CV (constant voltage) and CC (constant current) capability. You'll want max voltage of 30V or so, which will allow you to power up op-amps (i.e. part may specify +/-20V).
