Thanks for the suggestions!
Current was rising quickly but seemingly linear.
> Double and triple checked the pinout?
It turns out I'm an idiot
Somewhere along the line I switched up the leads on the power supply so I was passing voltage in the opposite direction, which this circuit was never built to handle, so any number of things could have become messed up
But I know for sure they were correct at one point - so there must have been another issue before (probably short or crappy soldering somewhere, I've been taking this chip on and off a few times now) which got fixed and then
I didn't notice due to reversing the supply
> Schematic shows GNDREF being connected to the power supply negative, but layout+photo doesn't seem to confirm this?
They're connected, on the layout you can see a lttle rectangle on GNDLOAD jack where it's tied to the main ground plane
> Unrelated comment for future reference: this layout of paralleling standard resistors gives really poor accuracy on the current measurement.
Thanks for the tip! I sort of assumed that the resistor errors would average out, but I guess then that the way current flows through them + temp variation just screws it all up?
Thanks for the help and sorry for wasting time!
