Recently I scored an adjustable DC bench PS capable of 350V and max at 0.2A (70W).
My current adjustable DC dummy load is capable only for much lower voltage, at 350V DC definitely will kill it instantly.
So in order to test the PS, the dummy load that capable at 350V with max current @0.2A, I've been thinking to use two 220V ordinary incandescence bulbs "in series", which are capable of voltage max at 220V x 2 bulbs = 440V, which is still above the PS max output, cmiiw.
The ideal load resistance is -> 350V / 0.2A = 1750 Ohm
As two bulbs in series -> 1750 Ohm / 2 bulbs = 875 Ohm at "on" resistance for each bulb.
Single bulb when connected to 220V power source -> 220V / 875 Ohm = 0.25A
So the right bulbs to use are rated at -> 220V x 0.25A = 55 Watt type.
Cmiiw please.
Aware that incandescence bulb has much-much lower resistance when cold, those above calculations on the bulb's resistance was at ON state at rated 220V voltage.
While in series, both bulbs at 350V, each one of them only will be powered at 350V / 2 bulbs = 175V each, clearly the bulb's resistance will be lower than at fully rated 220V.
Locally available bulbs which are close to above calculations are 40W or 60W, also others like 15, 25 or 75 Watt.
Questions :
1. Did I do it right ?
2. So the safest bulbs to use is 40W type instead of 60W for this particular PS load test ? It doesn't need to be precisely loading the PS at exact 0.2A, say tad lower is fine for me. Do not want to overload the PS than the rated current capability at 0.2A.
3. Any other matters that I missed or other considerations ?
TIA
