Got a new question, on the same subject, but not this design. I opened up a premium charger/discharger to see how it handles the voltage sensing. Looks like it is using components marked "E23", which after a search come up as biased resistor built-in transistor. The inputs from the cells go into the transistors and the outputs go straight to the mcu. And nothing it seems to take care of the grounding issue... Would this still be considered a 4 wire? Also, this is dividing the voltage, or reducing the voltage on the output, I understand that it can act like a regulator on the output, just not sure how that is calculated. All the cells use the same part, one for each cell.
