Author Topic: Inductor rise time questions!  (Read 809 times)
Offline ZeroResistanceTopic starter
« on: September 17, 2018, 06:54:08 pm »
So, let's say I have a
C = 1uF
L = 100uH
RL = 0.5 ohm (which I will ignore for this case)
and
1. Vc = 100V and I discharge this capacitor into the inductor and next
2. Vc = 500V and I discharge the capacitor into the inductor.
I would expect that as per the equation VL = L. di/dt. The rate of change of current di/dt is proportional to the ratio VL/L and since L is constant the rate of change of current should increase with V.
However for both cases I find (in LTspice) that the current reaches the peak value at the same time. I mean same rise time of current for both cases is the same.
I was expecting the case with the high Voltage to reach the peak current value earlier.
What am I doing wrong here or is my understanding wrong in this case?!
Thanks in advance!
Offline Benta
Re: Inductor rise time questions!
« Reply #1 on: September 17, 2018, 08:52:43 pm »
A sketch of your RLC connection would help. Right now I'm ????????
Offline bson
« Reply #2 on: September 17, 2018, 09:21:37 pm »
VL drops 5x as fast with the higher voltage, so while di/dt starts higher it also drops correspondingly faster.
