Hello EEVblog folks.
I am working on a hobby project making programable DC load. In the design I am using MAX6070 4.096V Voltage reference and MAX5717 unbuffered DAC. Two MAX44246 dual- low offset opamps are used as current sense amp, voltage reference buffer, error amplifier and difference amplifier for remote voltage sensing. The voltage reference is buffered and fed into the REF input of the DAC. The DAC's output goes to the non-inverting output of the error amplifier though 10k resistor.
And here comes the issue. Everything works well if the input of the Opamp is below 1.1 V. However above that value the opamp starts to draw obscene amount of current from the input and the DAC output voltage crumbles. I know that the DAC is unbuffered with 2k ohm output impedance and can't drive an appreciable current, but this shouldn't matter. The MAX44246 has mere 1250pA input current by spec but i am measuring 100 uA of input current at DAC Full scale.
What the OPAMP is going on? Am I doing something fundamentally wrong? Do i have defective opamp or what. I have attached some images of the circuit and the measured input current and DAC output voltage as a function of code.
ps. I have already disconnected the DAC from the Opamp and checked its output. The DAC operates in spec.
Thank you!
