Author Topic: injection transformer "termination"  (Read 568 times)
Offline exeTopic starter
  • self-educated hobbyist
« on: February 11, 2020, 05:44:56 pm »
Hi!
I want to reproduce this experiment: [1]. I have two questions about this schematic: [2] (I attach copy of the image for the sake of convenience).
1) What's the role of R4? Does it need to match R3?
2) Why R3 is 10 ohms and not something else? 10 ohms looks quite low to me. I usually see 50 ohm, is it to match siggen impedance?
PS on a second thought, may be R4 and R5 are a resistor divider, but still I'm not sure it is needed because transformer makes R3 "visible" on the primary winding. So, R3 and R4 can be replaced with a single R3 with 5 ohm resistance.
References:
[1] https://wiki.analog.com/university/courses/electronics/electronics-lab-loop-gain
[2] https://wiki.analog.com/_detail/university/courses/electronics/amlg_f3.png
« Last Edit: February 11, 2020, 05:49:25 pm by exe »
Offline fcb
    • Electron Plus
Re: injection transformer "termination"
« Reply #1 on: February 11, 2020, 06:20:52 pm »
This has the same ground on both sides?  Can you show how this is inserted into the FB loop of your DUT/system? Think there is some context missing that will help.
Reason you might have the resistors (R3/R4) either side is to reduce the effect (and phase shift) that the transformer introduces to the local FB. Try and imagine what it would look like without them.  Same reason that the 100ohm (R5) is many times bigger than R4, it reduces the effect that load variation will have on the operation of the circuit.
Ignore that - just had a look at your linked sources.  The OPAMP is the DUT.
You could reduce the 100R if your signal generator has the drive; 100R will have a protective function to your signal generator.
R3 is the part you are injecting across, it is low so that you don't affect normal operation of the circuit - Dr. Ray Riddley has an excellent set of videos that show this.
« Last Edit: February 11, 2020, 09:55:16 pm by fcb »
The following users thanked this post: exe
