It's used with "4-wire" resistance measurement technique to null out the voltage drop across the voltage test leads.
Given that small resistance, the large tabs are probably to support a large current flow and the smaller ones for the voltage reading.
I have a new doubt, how do I distinguish which is pin 1, which is pin 2, which is pin 3, and which is pin 4. In its datasheet, I did not find a specific and clear description. The extra thing I want to know is that it seems to be quite large, is there a smaller package?
Well look at the data sheet for part specific pin designations, but there is pretty much an industry standard for all parts that, looking from the top of the part, pin 1 is the one with some kind of mark or other designation that singles it out, and then pins are numbered counterclockwise from there.
A quick look at the data sheet shows a pinout diagram with pins designated E1, E2, and I1, I2. It shouldn't be too hard to work out which are the current carrying pins (Ix) and the voltage measurement pins (Ex) from the clues in the letters chosen for the pin designations. As expected, the current carrying ones are larger, the voltage measurement ones smaller.
Size will be related to power dissipation, which in turn goes hand in hand with current rating and resistance (P = I
2R). These are rated at 3W dissipation, which is quite chunky for any surface mounted part, so the part is chunky. Calculate its area, and that 3W power rating comes out at (crudely) 30kW/m
2. Toasty, it's gonna need a
lot of copper area to keep it cool.
