Author Topic: using multple power supplies  (Read 2134 times)
Offline funkimunkyTopic starter
  • Country: scotland
« on: November 09, 2012, 03:16:01 pm »
I want to learn how to use transistors and op amps. I would like to use 3 separate power supplies to get +15v -15v and a input signal of around 2v. Is it ok to use 3 different power supplies one for each required voltage? if so what is the way to do this?
Offline jeroen74
Re: using multple power supplies
« Reply #1 on: November 09, 2012, 03:51:55 pm »
Yes, as long as they are all floating.
