Author Topic: Grounded grid linear amp, idling grid current question?  (Read 3297 times)
Offline Chris WilsonTopic starter
  • Race car engineer, dog lover, hoarder.
« on: October 31, 2012, 12:54:20 pm »
I am restoring and converting a Henry RF generator that uses a 3CX3000A7 valve. I am at the stage where I am running filament current into the valve, running the blower for cooling, and monitoring filament voltage and current, and PA grid current. Filament voltage and current are correct. There is no drive being applied to the amp, and no output load. The OE metering shows zero grid current. Is that to be expected without any HV applied to the anode? I believe it will need the HV turned on to show any idling grid current, but wanted to be sure. Thanks.
Best regards,
                 Chris Wilson.
Offline djsb
Re: Grounded grid linear amp, idling grid current question?
« Reply #1 on: October 31, 2012, 01:07:34 pm »
Is it any of these you are talking about
http://www.n4tze.com/henryRFgenerators.htm
David.
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
« Reply #2 on: October 31, 2012, 01:18:33 pm »
Similar, it's a 2000D model, manual is at http://www.gatesgarth.com/henrymanual.zip
Schematic of RF section in question below, thanks David
Best regards,
                 Chris Wilson.
