Hello,
Sorry for my bad English, but i have never learned English.I have a question about the Instrumentation Amplifier.
I am using INA828 for the current sense through the voltage drop on the resistor. I will be measure current flow in to the DC-DC convertor.
I need measure current only when DC-DC convertor is running without load, so the current flowing into him shoud be between 10-14 mA.
Circuit connection is shown in the attachment.
Input voltage is 5V DC
Resistor is 0,27R
Gain is set to 501
Vs+ =s +10V
Vs- = -10V
By my calculations for the output voltage shoud be 1,353V(10mA) - 1,894V(14mA) depends on the current.
So my question is when i turn on the load of the DC-DC convertor, there shoud be current flowing through the resistor about 140mA. Can it cause some damage to the INA828, because voltage drop on the resistor will be 0,0378V and output voltage would try to achieve 18,938V but it is impossible with supply voltage i have using.
Thank you very much.
