Author Topic: Help designing serial-input 2-bit DAC  (Read 1442 times)
Offline matherpTopic starter
« on: March 20, 2018, 05:42:12 pm »
I'd appreciate help with what should be a simple design but one I can't get my head around.
I've got a two-wire 3.3V SPI output with a 25MHz clock. I want to pair up consecutive data bits such that I get an analogue level ( 0, 1.1V, 2.2V, 3.3V) at a frequency of 12.5MHz. The DAC output impedance can be high so a simple R2R output is fine. I need three of these for the application and to keep the component count to a minimum.
There isn't a way of getting parallel output from the uP at this speed so changing from the SPI source is not an option and of course I don't have additional signals for thing like a latch or reset input.
Any ideas gratefully received.
« Last Edit: March 20, 2018, 05:46:31 pm by matherp »
Re: Help designing serial-input 2-bit DAC
« Reply #1 on: March 20, 2018, 06:19:36 pm »
I mean't R2R as in just passive resistors - that is the easy bit it is the rest I'm struggling with
Offline Bassman59
  • Yes, I do this for a living
« Reply #2 on: March 20, 2018, 06:24:35 pm »
SPI isn’t two wires, it’s three at a minimum (clock, chip select, data).
Can you do I2C instead? There are many I2C “expander” chips with parallel output that you could use for your DACs.
« Reply #3 on: March 20, 2018, 06:27:11 pm »
Ignore the CS, it is permanently selected. There of lots of ways I could do it at lower speed but the key requirement is the 25MHz down to 12.5MHz
Offline Bassman59
« Reply #4 on: March 20, 2018, 06:28:57 pm »
Hopefully the DAC circuit has a reset, so at least there is an initial condition.
Without a CS, the DAC will update with every shift clock, which might not be acceptable for the application. With the CS, the rising edge can be used as an update.
« Reply #5 on: March 20, 2018, 06:33:30 pm »
But there isn't and can't be an active CS.
A divide by 2 off the clock can be used to latch the output for the two cycles.
Sorry if I didn't explain well enough but I have just two wires, one with a 25MHz clock and one with synchronised data. I need each pair of data levels to set an output to one of four levels for the duration of the next two clock cycles.
Offline mikerj
« Reply #6 on: March 20, 2018, 06:37:47 pm »
If you are transmitting data continuously then it's difficult to see how this could work reliably without some kind of chip select or reset.  A single glitch on the clock will throw the TX and RX shift registers out of sync and they would never recover from that point.
If there is a delay between successive DAC updates you may be able to use something like a retriggerable monostable on the clock line to detect missing clock cycles and provide a latch signal.
« Last Edit: March 20, 2018, 06:40:32 pm by mikerj »
« Reply #7 on: March 20, 2018, 06:41:42 pm »
I do have a gate every 704 clock pulses that can be used to reset but nothing more frequently
Offline David Hess
  • DavidH
« Reply #8 on: March 21, 2018, 12:14:12 pm »
Two D-flip-flops configured as a shift register can feed a 2-bit latch which is clocked at half of the clock rate to produce a 2-bit parallel output.  The shift and latch functions can be combined in a single MSI (medium scale integration) chip like an 8-bit shift register and latch while ignoring the extra bits.  The gate every 704 clock pulses can be used to maintain synchronization.
