I am a complete novice at electronics and would much appreciate some help with this simple project.
I am making a 12v auto door closer for my fowl house. It consists of a battery, a photoswitch and a car door lock actuator. The actuator is a sealed unit but I am pretty sure it consists of a 12v motor and some gears.
The load from the photoswitch is connected to the VCC terminal of the delay timer with a loop to the common terminal of the module. Under test but with no load the device works fine. When the light drops to the appropriate level the power flows to the delay timer which switches after the set number of seconds.
However when I connect the actuator to the NC terminal of the delay timer module it does not switch and keeps powering the actuator. The same thing happens when I try to run the actuator directly from a 12v digital time switch. The relay component of the delay timer is a Songle SRD-12vDC-SL-C and it is supposedly rated for 10 amps at 30V DC.
The actuator pulls in about one second and then continues to draw 1.8 amps (I think - on the 10A setting the multimeter reads 1.
Would a 30A 12v automotive relay added in series help?
Thanks. I hope this question is not too dumb.
