Electronics => Beginners => Topic started by: carbon dude oxide on April 02, 2013, 09:15:48 pm
Title: interfacing with a a070vw05 v2 screen
Post by: carbon dude oxide on April 02, 2013, 09:15:48 pm
hello :)
i found this a070vw05 screen in my box of spares and i was wondering if there was a way of interfacing it to my raspberry pi so i can use it?
here is the datasheet : http://www.avidia.com.tw/docs/product/A070VW05%20V.2.pdf (http://www.avidia.com.tw/docs/product/A070VW05%20V.2.pdf)
so far i have been able to get the back light powered up and it does not look like it has any dead pixels so its looking like a nice 7in screen so far :)
i do also have a "3609 SY 9901 FOR A070VW05 LCD" board that the screen connected to. This board also has a connector which i believe went into the small net book it came from.
i do hope that it is possible to interface this screen as it would fit nicely in making my pi a portable games arcade :D
Title: Re: interfacing with a a070vw05 v2 screen
Post by: Zapro on May 11, 2013, 10:04:08 pm
I am sorry to say this: If You have to ask, you won't get it working with your Pi.
It's a very complicated affair to make it work with another controller than it was originally married to.
// Per.
Post by: Rasz on May 11, 2013, 10:16:45 pm
You can drive this lcd with beagleboard/bleaglebone as it has parallel interface for lcds
Post by: amyk on May 12, 2013, 09:43:21 am
I can't open your datasheet for some reason, but given its origin it's most likely a standard LVDS panel. That board you have is the T-con for it and turns LVDS input into the signals needed to drive the panel.
A quick Google suggests the RPi has LVDS output. How difficult it is to actually connect and get a display working, I'm not sure (Broadcom proprietariness |O)
Post by: Rasz on May 12, 2013, 11:55:12 am
not an lvds panel
RPI doesnt have lvds
