Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Zener circuit not working as expected
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Zener circuit not working as expected (Read 1300 times)
@rt
Super Contributor
on:
March 05, 2020, 03:12:15 am »
False alarm.. mods please delete.
Transistor was shorted collector to emitter.
Last Edit: March 05, 2020, 04:02:47 am by @rt
Logged
greenpossum
Frequent Contributor
Country:
Re: Zener circuit not working as expected
Reply #1 on:
March 05, 2020, 04:03:44 am »
Even so, you need to calculate the series resistor so that you're running the zener on the slope, not where a little leakage current will turn on the transistor if it has enough gain. A zener is not a perfect threshold switch.
Logged
Zero999
Super Contributor
Country:
0999
Reply #2 on:
March 05, 2020, 10:00:54 am »
And a zener probably isn't required in this application, just use a higher value base resistor. The relay is also missing the important flyback diode across the coil, to protect the transistor against the back-EMF, when it turns off.
Logged
JoeyG
Regular Contributor
Country:
Reply #3 on:
March 05, 2020, 10:35:32 am »
No diode snubber across the coil to protect the transistor???
Logged
@rt
Super Contributor
Reply #4 on:
March 05, 2020, 01:11:09 pm »
No, the transistor was out of a junk box and already no good.
My circuit does have the protection diode, caps for the reg, and another diode for reverse polarity protection.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
