Author Topic: Interpreting results from my scope  (Read 689 times)
Offline iamsethTopic starter
« on: October 09, 2019, 11:19:15 pm »
I have a 555 setup in monostable mode.
I probed the output (pin 3) and the capacitor (pins 6 &7) to channels 1 and 2 respectively. The waveform looks like the one in the datasheet except I get some noise after the capacitor is charged up. I've attached the scope output image.851492-0
My values for R1 and C1 are 1M and .1uF.
Is this a concerning result and if so, what should I change to fix the issue?
Offline StillTrying
  • Country: Broken Britain
Re: Interpreting results from my scope
« Reply #1 on: October 10, 2019, 12:35:10 am »
It looks like the triggering pulse on pin2 is longer than the monostable time, and it needs 100n across its supply pins.
I think the GND is rising when the DIS pin starts to discharge the cap.
« Last Edit: October 10, 2019, 12:51:56 am by StillTrying »
Offline vk6zgo
« Reply #2 on: October 10, 2019, 12:36:17 am »
I probed the output (pin 3) and the capacitor (pins 6 &7) to channels 1 and 2 respectively. The waveform looks like the one in the datasheet except I get some noise after the capacitor is charged up. I've attached the scope output image. (Attachment Link)
It is not unusual to get a bit of "overshoot" or "undershoot" with fairly sharp transitions in "real life".
If you reduce the time/div & just look at the transitions, you will probably find they are sinusoidal.
Because you are using a fairly long time/div setting, the 'scope makes a sort of "best guess"of the waveshape, hence the "squarish" look .
On reflection, they are also low amplitude, so accurate representation of them will also be limited by the resolution of your ADC, so you will probably need to reduce the volts/div control as well.
