Graphite sheets are better in thermal conductivity. But is it conduct only in surface. I mean if we place graphite sheet between processor and heatsink , will the heat transfer from processor case to graphite sheet and from graphite sheet to heat sink.
Some are saying that graphite sheet conductivity will very low across surfaces(z axis). High in x, y axis..
Is this true ??
Thanks.
Vignesh.M
