Author Topic: handskit solder station t-12 wiring diagram  (Read 3882 times)
Offline ascarons22Topic starter
« on: June 14, 2023, 07:44:12 pm »
Hello everyone, by recommendation of the user DeividAlfa I created this entry, I have a handskit pcb of a t-12 soldering station, which I have loaded the Deivid custom firmware, but I can't find the configuration for the pencil wiring welding, the original has 4 cables and does not have a thermocouple in the handle, and the pcb has 5 pins, but I cannot get the connection right, would someone be so kind as to help me? It is to connect a t-12 handle that I know some users They have it, please help.
Offline Jwillis
Re: handskit solder station t-12 wiring diagram
« Reply #1 on: June 15, 2023, 03:10:54 am »
These units rely on a thermal couple in the handle as a sense to regulate the temperature . It tell the unit when the element needs to be on or off depending on the temperature setting. The driver unit will do nothing without it. The motion switch in the handle for these types only needs to deliver a single pulse to pull the unit out of standby. So for this unit to work you need a 5 pin pencil iron.
Online DavidAlfa
« Reply #2 on: June 15, 2023, 03:43:34 am »
It will work without temperature sensor, using the stm32 built-in, but it seems there's a small smd sensor in the board itself.
- H/T+ is the heater positive (First one, closest go the end of the cartridge).
- G is the negative (second ring in the tip).
- Earth is the bottom pin (The one with the earth symbol) and goes to the final contact, which is the entire tip casing.
- The vibration switch goes to SW, it's connected to the tip negative inside the handle.
« Last Edit: June 15, 2023, 03:57:41 am by DavidAlfa »
Offline Jwillis
« Reply #3 on: June 15, 2023, 05:42:57 am »
Ok. So your using the thermal coupler built in the T12 . I understand now. SMD on board is for comparing the ambient temperature and tip temperature for better calibration.
Offline Nusa
« Reply #4 on: June 15, 2023, 05:55:52 am »
In T12 tips, the tip thermocouple is in series with the heater. When heating, the thermocouple is just a wire. When sensing the heater is just a small resistance (about 8 ohms). Up to the software to determine how often to sense.
Online DavidAlfa
« Reply #5 on: June 15, 2023, 08:38:47 am »
Yes, but not critical,a variation of 5-10°C won't change anything in real life.
« Reply #6 on: June 15, 2023, 12:05:50 pm »
Thanks David and sl rest, the biggest problem was that with David's Firmware the station went crazy, first it did not work,Thanks David and sl rest, the biggest problem was that with David's Firmware the station went crazy, first it did not work, by my fault, since when reThanks David and sl rest, the biggest problem was that with David's Firmware the station went crazy, first it did not work, by my fault, since when removing the connector mThanks David and sl rest, the biggest problem was that with David's Firmware the station went crazy, first it did not work, by my fault, I solved it and continuously did not detect the t12 tip, but when I took it out once it made contact and I realized that the handle was misconfigured, I read the whole post of David's Firmware and did not find the wiring and missing the thermistor more confused me, until David recommended me to open a post and thanks to him now I know how to connect it,  As I prove it I will publish result. Best regards.
Online DavidAlfa
« Reply #7 on: June 15, 2023, 05:34:16 pm »
I don't know what happened here, but your message seems to have passed through a defective space-time wormhole   :D.
« Reply #8 on: June 16, 2023, 12:32:51 pm »
I don't know, I see the message correctly, yesterday I was getting many 502 bad gateway errors when trying to access the forum. Today I reconnect and try again.
« Reply #9 on: June 16, 2023, 07:21:03 pm »
At the moment I just bought a ksger v 2.1 pcb, the handskit pcb sometimes detects it and sometimes it doesn't, so something happens to it, I tried it connecting directly with 3 cables, it worked for a few seconds and stopped working, ntc error not detected So I just bought another pcb and for what it's worth the ntc of the pcb is 4.7k.
Online DavidAlfa
« Reply #10 on: June 16, 2023, 07:56:04 pm »
Probably it has a fake stm32, it causes the "cursed" readings, everything freaks out.
« Reply #11 on: June 17, 2023, 10:47:28 am »
Last night I ordered a Stm32 from a link you posted some time ago and reloaded the handskit firmwareLast night I ordered a Stm32 from a link you posted some time ago and reloaded the handskit firmware until the order arrives, now I have decimals in temperature, Chinese stuff, I will be publishing progress, greetings
« Reply #12 on: June 17, 2023, 12:03:42 pm »
Ok, confirmed, it's fake,  :palm: When checking the first time I did not look at the adress, but in the lower text box and seeing 0410 I gave it for good, today when I looked again I saw the adress and this starts with 100, my error, but well, so I have 1 extra welder.
« Reply #13 on: June 17, 2023, 05:42:10 pm »
Guess what?, I had a cc3d controller of a drone, Stm32 f103 authentic, it is already working, perfect stability, 0 temperature variation, thank you really, when I collect I will remember your help.
Online DavidAlfa
« Reply #14 on: June 17, 2023, 05:51:31 pm »
Great!  :-+
« Reply #15 on: June 23, 2023, 05:08:33 pm »
Enjoy the beers from  Galicia. Greetings
Online DavidAlfa
« Reply #16 on: June 23, 2023, 06:41:41 pm »
Really? I am too!  :-+ What city?
« Reply #17 on: June 24, 2023, 06:16:45 pm »
Jaja, No, I live 40km from Bilbao, yesterday I made a PayPal for help, that's why I saw that you were from Galicia, both from the north.
Online DavidAlfa
« Reply #18 on: June 24, 2023, 07:55:22 pm »
Ahh ok! Nice city too! I always returned with severe overweight after spending few days there  :-DD.
Thanks for the beer! :-+
Offline Richyread
« Reply #19 on: November 27, 2024, 12:31:07 pm »
I have the same station and have been trying to get the handpiece trigger switch to function.
Looking at the detail in the previous posts, I think my handpiece connector is wired incorrectly.
5pin Board Output Pins:
Pin [1] - SW
Pin [2] - G
Pin [3] - E
Pin [4] - T+
Pin [5] - H
So to wire up the handpiece, the expected inputs would be as follows:
5pin Handle Output Pins:
Pin [1] - Trigger Switch
Pin [2] - Neutral (+ Trigger Switch)
Pin [3] - Earth
Pin [4] - Positive
Pin [5] - empty/unused
However, on my handpiece the (moulded) plug has Pin [1] - empty and Pin [5] populated.
Given the layout of the control board (shown in first post) to get a functioning handpiece, would that mean I need to either:
 a) Buy a new handpiece
 b) Replace the GX12-5 cable connector, to enable switching of wiring to pins 1&5
 c) Remove the existing solder bridge between 'H' & 'T+' and then create a new bridge between 'H' & 'SW'?
I.e. remove the physical link between Pin [5] & Pin [4] on the control board, and create a new link between Pin [5] with Pin [1]
For speed, the 3rd option would seem the most straightforward, but before I take it apart for the 3rd time wonder if someone may be able to double check my logic etc.
Richy.  :-+
« Reply #20 on: December 14, 2024, 10:28:43 pm »
Pin [1] - SW
Pin [2] - G
Pin [3] - E
Pin [4] - T+
Pin [5] - H
Pin [3] - Earth
Pin [4] - Positive
Richy.  :-+
Did you try what you wrote and it worked for you?, until now I had only used 2 tips, but when you place several new ones it does not detect them, but with another station ksger v 2.1 scheme it does detect them, so I am at that point of redoing the soldering iron, how did it go for you?
