I have a few low ohm power resistors, but nothing for any amount of power at mains 120/240V or 380V in SMPS. Ages ago I ordered a cheap bag of 3k, 2W Carbon composite resistors on ebay, they look like light blue cement or chaulk.
So I soldered up a perf board with 6rows * 8columns in parallel, and the legs match well by luck, and I plan to put it in a box with a fan, and some switches for different total load. For 2W each they can handle (in ebay land) 26mA @ 77V continuous (2945ohms avg) .
But when do they really start cooking/changing from factory spec's ?
So if these are just your basic cheap Carbon composite resistors, what type of pulse power might be too much and damage them inside ? I should destructively test some, but not in the house.
At some voltage I'd have to worry about arcing, but I'm not using those voltages yet.
