Author Topic: Learning how to use an Hp8903a  (Read 2642 times)
Offline reddish75Topic starter
« on: March 28, 2017, 03:05:10 pm »
Hi, looking on how to use a HP8903a properly for testing amplifiers etc,
With the pic in the link below I'm measuring the output of my Leader Lag-120b its set at 20khz as you can see but with the distortion is it measuring at 0.0261? Am I reading that correctly?
Thanks
https://1drv.ms/i/s!AhyV-hIo37nZp1toa_ezUTaw0ykp
Offline barry14
Re: Learning how to use an Hp8903a
« Reply #1 on: March 28, 2017, 11:20:27 pm »
The % annunciator is lit so the reading is 0.0261% which is a reasonable value for distortion of an audio generator.
Offline metrologist
« Reply #2 on: March 28, 2017, 11:22:24 pm »
That's cool, I have an 8902 I'd like to learn how to use...
« Reply #3 on: March 29, 2017, 02:25:04 pm »
Thanks for that, so to test the specs (shown in pic in link below) what would I set it to?
https://1drv.ms/i/s!AhyV-hIo37nZp1zH-iwmeTakJGeg
Offline Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
« Reply #4 on: March 30, 2017, 01:00:19 am »
The manual for this is here:
http://exodus.poly.edu/~kurt/manuals/manuals/HP%20Agilent/HP%208903A%20Operation.pdf
End of section 1 has some basic measurements explained and 3-38 onwards details each of the options.
TonyG
Offline Tony_G
    • TGSoapbox
« Reply #5 on: March 30, 2017, 01:03:27 am »
This guide will take you and a signal generator through the key functions of an 8902A.
http://www.keysight.com/upload/cmc_upload/All/EPSG085831.pdf
TonyG
Offline metrologist
« Reply #6 on: March 30, 2017, 02:59:54 am »
Thanks Tony!
Offline Tony_G
    • TGSoapbox
« Reply #7 on: March 30, 2017, 03:21:32 am »
NP, it's a fantastic guide in my opinion to show the basics of the 8902A. The only downside is that it assumes you know why you'd want to measure what you're measuring.
The 8902A is a great piece of kit. I went out and bought the microwave down converter (11793A) for mine. Been very happy with it.
If you don't have the 11722A Sensor that goes with it then you can build your own. I did a video on it here:
https://youtu.be/39UZNyCStoU
TonyG
Offline macboy
« Reply #8 on: March 30, 2017, 02:49:41 pm »
8902A != 8903A
Offline Tony_G
    • TGSoapbox
« Reply #9 on: March 30, 2017, 03:56:17 pm »
Correct but Metrologist asked about an 8902.
