Author Topic: instead of 20K potentiometer 2 x 10K potentiometers  (Read 5375 times)
Offline SavethedayTopic starter
  • hobby technician
« on: August 26, 2017, 11:37:10 pm »
Hi
I would like to know how to use instead of one 20k potentiometer, 2 x 10K ohm potentiometers.How should we hook up 3 pins?
A 10K          B 10K
l    l    l        l    l    l
A1 A2 A3   B1 B2 B3
A2 connected B1
and
A1 B2 B3
Does it work like that?
thanks.
Offline wraper
  • Country: lv
Re: instead of 20K potentiometer 2 x 10K potentiometers
« Reply #1 on: August 26, 2017, 11:57:45 pm »
Depends on what you want to get as a result. If you want to regulate total resistance in 0-20k range or if it works like voltage divider (like sound volume regulator) are two completely different cases.
  • hobby technician
« Reply #2 on: August 27, 2017, 12:02:42 am »
I need to use one 20K potentiometer but right now I don't have it.So I thought I could use two 10K.
Offline wraper
  • Country: lv
« Reply #3 on: August 27, 2017, 12:06:14 am »
You did not answer the question of what you want to achieve. In many cases you could just use one 10k Resistor. In other cases you might add 10k fixed resistor in deries.
« Last Edit: August 27, 2017, 12:08:07 am by wraper »
  • hobby technician
« Reply #4 on: August 27, 2017, 12:11:25 am »
Ok I need to go 1 ohm up to 20k ohms.
Offline wraper
  • Country: lv
« Reply #5 on: August 27, 2017, 12:18:32 am »
1 ohm? If you said 0-20k, it would appear fine. But 1 Ohm implies you want to achieve at least remotely precise resistance at such low range which is not real with 20k of total resistance.
Offline ludzinc
    • My Misadventures In Engineering
« Reply #6 on: August 27, 2017, 01:48:35 am »
Give the newbie a break and stop tormenting the guy.
Offline wraper
  • Country: lv
« Reply #7 on: August 27, 2017, 08:34:34 am »
Who is tormenting anyone? I rather try him to avoid wasting time and tormenting himself by doing thing inadequate for particular purpose.
Offline sasa
  • Hobbyist in electronic
« Reply #8 on: August 27, 2017, 09:32:23 am »
Two pins are enough (one of  border and middle one), if that is simpler for you. Or you can do as already suggest. Only take care on which direction you want to rotate knob to manage resistance - then use appropriate pins. If minimum resistance of 1 ohm is necessary, ensure one in series (or cheaper make one 10x 10 Ohm in parallel),
When I  made constant load circuit, it certainly I did not wanted expensive multiple turns pot in order to calibrate current precisely. Instead, I used several different values pots, similar you required.
It actually depends what precision you need. If not critical, 2x 10k pot in either connectivity (use 2 or 3 pins) is sufficient.
If you want to use 2x 10K pots instead 1x 20K as voltage divider, that is a bit more complex indeed and you have to specify a bit desired ratios.
« Last Edit: August 27, 2017, 10:23:20 am by sasa »
The 30+ years professional desktop software designer and software engineer
The following users thanked this post: Savetheday
Offline wraper
  • Country: lv
« Reply #9 on: August 27, 2017, 03:34:38 pm »
The issue with connecting only 2 pins is that if potentiometer is crappy or wears out, when adjusting it, connection may get lost for a brief moment and it becomes open. In some applications (like PSU) it may case grieve consequences (like high voltage spike somewhere in the cirquit). Therefore it's better to connect middle pin to one of the side pins, so maximum possible resistance is limited even if slider connection is lost.
Offline sasa
« Reply #10 on: August 27, 2017, 03:48:03 pm »
Indeed. And because of that it is always better to give a hint what is doing and with what. I have never had a problem with metal pots on breadboard during initial tests hooking it in 2 wire configuration, however with plastic pots or even stocking trim-pots that is quite often bad decision.
I supposed this is just temp solution while acquire exact value pot for permanent use.
Offline Brumby
« Reply #11 on: August 28, 2017, 01:56:09 am »
Not necessarily.  The OP may just need to ensure there is never a dead short.
But this is just more speculation ... having a bit more of an idea of what this 20K will be doing could make for a more focussed discussion.
Offline Zero999
  • 0999
« Reply #12 on: August 28, 2017, 08:16:57 am »
Do you mean, you need a minimum resistance of 1Ohm or you want the resistance to be able to go down to 1Ohm or under?
If you need a minimum resistance of 1Ohm, then adding a series resistor will do.
If you need a minimum resistance of 1Ohm or below, then that's more tricky, as the wiper's contact resistance may be higher than that.
